Fick tag i en -07 motor med EFI från england, med tillhörande kablage, styrenhet och allt annat som behövs för att starta upp den. Förutom bränsletanken, men det är inte svårt att fixa.
Listan över kommande renovering av motor.
1. RC basic cvt kit - tst two stage varaitor kit, roller weights, 1,500rpm torque spring
2. heavy duty clutch 1,500 rpm clutch spring included
3. PG heavy duty cltuch bell
4. NCY contra spring bearing to eliminate binding
5. heavy duty race torque driver
6. daytona kevlar race belt
7. 14t gear set - with oem yamaha gasket
8. 65mm bbk - forged race piston
9. upgrade RACE cylinder aluminium/nikasil cylinder
10. race camshaft
11. KOSO adjustable cam gear
12.hi-flow cylinder head - 24mm intake valve
13. 3D billet valve cover super heat sink
14. RC billet cam cover breather
15. PG aluminum oil catch can
16. +2.2mm stroker crank - with forged double H race conrod
17. +8mm stroker crank with forged double H race conrod, cylinder spacer, longer studs, longer chain
18. RC PRO oil cooler - KOSO billet cover, KOSO hi-flow oil pump, oil cooler
19. PRO starter - billet mount
20. injector - 10 hole injector
21. KOSO 30mm throttle body
22. NCY direct ignition
